e39dream
- October 28, 2006
- chicagoland
- '93 sport 4x4 dark green
hey guys- I have been working on my explorer for a couple few hours a day the last couple weeks desperately trying to get it running, heres my scenario.
I had diagnosed the truck with a bad fuel pump about 1 year ago with the help of this forum. The truck had to sit for some months becasue I couldn't afford to fix it- the fuel pump was the straw that broke the camels back so to speak. I have a car to keep going too, but I need a work vehicle- the explorer.:navajo:
I came into some money and put new fuel pump in, as well as all the other things I could think to do while I had some time on a friends lift, shocks all around, brake lines, front u joints and wheel bearings, had to weld in new front shock mounts, replaced some big doughnut bushing in the front end. Ended up finding the rear leaf spring shackles so rusty you can poke your fingers through them- if you have a set of rear shackles for sale from a part out or something please let me know!!! I just dumped over 400 bucks in parts on this thing and still need a rear brake job. Heres the best part- IT STILL WONT START/ RUN!
The old fuel pump broke off at pump side of both lines when lowering the tank- rusty. The larger diameter vehicle side line was very hard to remove the old pump line piece from- ended up pulling the spring clip out of the fitting. Installed new pump- smaller line clicked right in of course, larger line snugs up but no click. Test everything and nothing appears to leak, no fuel smell. Lots of fuel to the injector rail coming from the schrader valve. I noted if you bleed the fuel system via the scrader and come back to it the next day there is zero pressure at the schrader, not even a drop of fuel until you key it or run the pump again. The truck runs on ether spray start fluid. The injector pulse is present when cranking, tested with 12v test lite.
Do you guys think that fuel line fitting not clipping into place is causing it to not leak but lose system pressure? I mean there is zero odor or liquid leakage near the tank at all. I've already tried to get the larger diameter line from parts places locally and online, its ford dealer only. I'm afraid to find out thier cost. What about replacing it with heavy rated PSI rubber fuel line and regular hose clamps- would that work?
The only other thing I can think is that the fuel pressure regulator is bad but I don't have a vac pump to test it- is there another way to test the reg?
thank you for any ideas/suggetions you may have and for taking the time to read my saga. Mark
