magicd
- January 7, 2010
- Arnprior’s , Ontario
- 2004 XLT
Hey all,
2004 Explorer will not crank, this has happened before and figured it was a finicky Neutral Safety Switch.
However, I’ve verified the following;
There is constant voltage to starter.
No voltage to smaller terminal on starter solenoid when key turned to start.
Fuse #12 (50a) located in Power Distribution Box is fine.
Fuse # 29 (10a) in the Central Junction box is fine.
Constant Voltage to terminal #30 of the starter relay.
Voltage to terminal #85 of starter relay when key turned to start. This should eliminate both the ignition switch and the NSS.
If the starter relay is removed, and jumped across terminals 30 and 87, starter will turn but truck will not start, even with key in start position.
Terminal 87 is grounded, as I used an ohm meter with alarm from terminal 87 to neg post of battery.
Questions: Should terminal 86 also produce a continuity alarm when connected to neg post? Or, is there possibly a grounding/wiring issue with the starter?
