mp88
- February 26, 2007
- Nesquehoning, PA
- '98 Sport
Ok, this is the biggest annoyance I've had with this truck yet. I have a 94 XLT 4x4. Changed the transmission fluid around 4,000 miles ago. The fluid is a stable red color and not low.
A while ago while I had a mattress on the roof, the check engine light came on while I was going up a hill. Every so often when I have the engine under what I'd like to call strain (accelerating at the bottom of a gear) nothing happens. I gain no speed. Even downshifting does nothing but rev and keep me at the same speed.
If I keep it strained, especially on a long highway going uphill, I sort of lose 4th gear. I can definitely tell that it has shifted from 3rd to 4th (I have downshifted into drive to confirm this) but it stays revved. About 500rpm higher than it should be. Then the check engine light comes on.
For example:
Normal highway driving: 65mph at 1900rpm.
Screwed up driving: 65mph at 2400rpm.
Does this sound like something simple such as a solenoid? Or is it time to ride this Exploder until it dies?
Thanks.
For example:
Thanks.
