AmetureMech
- September 10, 2017
- NY
- 2000 Explorer
Hi there. I have a 2000 Explorer V6 OHV 4x4 with a 5speed manual tranny. The other day driving to work it died on me. just cut out in the middle of 4th at like 2.2k RPM. truck was running smooth before with no lights and no issues at all
I notice that i still have oil pressure when I go to turn the ignition so i know i have compression.
I also notice that there is no telltale fuel pump sounds when I turn the ignition on.
First thing I try to do is eliminate the top three things. Spark, Compression (which I know I have) and Fuel.
Ok so Lets check for spark. I take a screwdriver and pull off a cap. No telltale arcing
So maybe I cant see the spark due to daylight. I buy a can of ether and spray it in while someone cranks it. Nothing. Ok so I change the coil pack. Still nothing...
Now Im at a dead end so I decide to check on the fuel pump.
I pull the rear harness plug, tap to the pump, and send it 12v. it runs fine! pumping and everything!
Plug it back in, and nothing.
Please keep in mind I recently change fuel pump relay, and I checked all the fuses. When I put the key in the on position the relay doesnt click. but when i start it, i can feel it click. there is also a relay under the dash thats clicking that i never knew was there before. but i even tried changing that relay and to no avail.
So now im thinking, ok maybe its the CPS (crankshaft sensor). but i recently just changed that. so whatever i go to the autoparts store and buy a new one. Changed it. nothing.
Last thing i did was clean the Mass Airflow Sensor
so now here i am. Personally i think my PCM is fried. any thoughts, suggestions, and or ideas? anything would be greatly appreciated, as this is my work truck and i kind of need it to run.
Thank you in advance for all your help!
206k on the truck
206k on the truck
