MistahYebba
- June 29, 2015
- Clearwater, Florida
- 2005 Ford Explorer XLT
I can't get my truck to start anymore.
I had a bad stall out and limped it home with no power brakes. It would stall at every red light. Could barely get it started.
But somehow made it home. Had to completely mash the brake pedal to slow down. Scary!
Now it's been sitting for 2 weeks and I've tried to get it started every day but I just can't.
It has something to do with air or fuel & the engine....... but I can't freaking figure it out... because I can't get it started anymore to diagnose the problem!
I did get it started just a handful of times in the past 2 weeks but it doesn't last long before stalling out.
But now I haven't been able to get it started at all the past couple days... so things are getting worse...
Main symptoms:
1. I got it started a few times during the last 2 weeks it's been sitting dead in my driveway. But it would run for like 2 minutes max before stalling out and not start anymore for a while.
2. Now it cranks still but won't start at all. It just keeps trying to start but won't.
3. If it did start, it would puff white/light gray smoke out the tailpipe at a rapid pace. But like I said, it won't start anymore anyway.
4. If it did start, it sounds like a pretty bad vacuum leak HISSSSSSSSSSSSSSSSSSSSSSSSSSS but there are no visual signs of a vacuum system damage anywhere. I checked everything & smoke-tested too. But it won't start anymore anyway so this is pointless. I also disconnected the brake booster from the equation to rule that out. Ya know, since I lost my power brakes?
5. If it did start, there was a very strong smell of gasoline. But remember, I can't get it to start anymore.
6a. One of the vacuum lines from the upper intake manifold had a few drips of gasoline when I disconnected it.
6b. One of the very last times I managed to get it to start, I heard it release a huge sound of "air" before instantly stalling out. Almost like air brakes releasing. --> And the upper intake manifold was VERY cold to the touch with tons of condensation on it.
7. Sometimes if I try too many times to start it up/keep cranking it for 10 seconds hoping it will catch and start... then the results just get worse... the starter stops trying it's best and just gives me one lame "uh". Nothin.
8. My coolant level is fairly low which means there is a leak or it's getting burnt off over time. Hadn't checked it for a bit but there was never any heat/cooling problems. Could this have anything to do with my symptoms?
What I did:
It's definitely not the battery or alternator. Although the battery was getting weak after sitting for 2 weeks and constant start attempts... so I have it on a charger now.
It's definitely not the ignition switch or starter. Although the starter is probably angry at me for keeping trying to start it for 2 weeks.
Fuel filter? Fuel pump? Fuel injectors?
PCV? MAF? TPS? EGR?
Head gasket?
It's gotta be something specific.... it was working every single day for 5 years until one random lunch break and all the sudden I had to limp it home... lost my power brakes.... horrible idle... stalling out.... no more starting....
must be something important.
Main symptoms:
What I did:
PCV? MAF? TPS? EGR?
Head gasket?
