pj8847
- March 18, 2005
- N.Y.C.
- '95 XLT 4x4 4.0L OHV
OD "shudder" on engagement... Opinions? **Solved**
Hey all, been a while since I posted here, mostly because I been laid up with a blown out knee...
Anyways, as the title says, I'm recently experiencing a "shudder" when the tranny (4r55e) in my '95 4.0l OHV explorer "shifts" into OD.
Now the tranny has always had the typical delay shifting into drive and reverse, but that has never been an issue. All gears engage fine, 1st is solid, off the line I spin the tires on my truck if i put the pedal to the floor (mind you, these are 31x11.50 rubbers) regardless if the ground I'm on is wet/dry, dirt, asphalt or concrete. 2nd, 3rd and reverse, again, all solid... It is just "OD" that I'm noticing the problem with.
I can replicate the symptoms on command: I get up to speed in third, to about 45mph (on the spedo, this is a note that will be addressed shortly), and OD will kick in... BUT if I am on the slightest incline, it will "shudder" going into OD, and I have to back off the pedal, and get back on it immediately and the shudder goes away. If I give it more gas when the shudder starts, it increases in direct relation to just how much more pedal i put into it. (I haven't pushed it to hard, as i don't need to blow up the dang thing)
At this point I'm trying to figure out the best place to start, as the tranny only has about 80k on it, and it was a NEW unit from ford themselves. I don't have a problem removing it from the truck and tearing it down, but before I do that, maybe someone might have a different thought as to what may be the problem.
NOTE: Two other things I thought I would mention...
First being, I obviously am not running the stock tire size, so i know the speedo is off by roughly 10mph @ 50mph (meaning, the spedo reads 50, but my GPS says I'm going about 60). Could me being to lazy to get the spedo corrected play a role in the shift patterns of the tranny being a bit off, thus creating a problem?
Secondly, I have also noticed recently, when coming to a stop, as the tranny kicks down to first gear, there is a slight "thunk" and the activation of my ABS system for a second. Unsure as to this having anything to do with the problem, it just may be another problem I'll have to deal with soon, probably T-case if anything, most would think U-Joints, but those are solid.
Ok, that's about it, fire away with your thoughts/questions, I'll try to answer what I can, and take all opinions into consideration BEFORE I rip into the tranny, although I'm hoping I won't have to.
