Alright guys, good news. Timing complete.
I did not do the balance shaft chain or balance shaft lower guide because I didn't feel like taking the block cradle off. Don't care enough, hopefully won't regret it.
I have also at this time put the timing cover and water pump back on. I have a few post-job hopefully I didn't royally eff up questions about that though.
I bought
this gasket kit on Amazon (not necessarily recommending it, this is just the one I ended up getting) and it included the grey RTV stuff.
I ended up using it on both sides of the timing cover gasket and ONLY the block facing side (or timing cover facing side) of the water pump. I remember someone in some video mentioning not to do both sides for the water pump and my intuition screamed loudly enough that I didn't do both sides on the water pump.
I'm pretty sure I either need to RTV the other side of the water pump or attempt to remove / redo the timing cover gasket. Or just leave it and see what happens.
Did I screw this up? How? Thanks.
Next up are the valve covers, which I have non-OEM replacements of. The mechanic I had do a leak down wrote that the passenger side VC was cracked. After removing the engine I visually inspected the passenger cover and I can't find any cracks, but I had already bought replacement covers before. I'm not sure how a decent shop got that wrong or if maybe I'm just not seeing it, but oh well. Part of me want to put the OEM covers back on TBH, but I'm probably not going to.
Oh I also removed the oil pan and cleaned it. It had a few timing system plastic chunks (very small ones) so I'm glad I did that. However I didn't do anything in terms of resealing the gasket. I just bolted it back on to the proper torque specs. Should I worry about that? RTV it?
The thermostat (I think, thing directly above WP), showed some signs of leaking. One of the three bolt thread area was more rusted than the others. I cleaned it up and put down a small amount of RTV. Hopefully that wasn't stupid. I don't have a replacement gasket for that one ATM. Worst case scenario that can be serviced in the car easily.
So once the harmonic balancer, valve covers, and I want to say the flexplate / flywheel are all back on, I think at that point it's time to put it back in. Oh right, I'm going to check the injectors and put the fuel rails back on too. Any tips on cleaning / inspecting those for debris?
Anything else I should do before switching gears to re-installation?
EDIT: Almost forgot, does the oil seal kind of just sit there? I was mega surprised to not see any kind of machined flat for that thing to sit on. I've replaced it with a new one.
