dillon1340
- September 13, 2008
- greenville, south carolina
- 1991 explorer 4x4
does anyone have experience with these? i have read about how important they are but when i rebuilt my transmission i do not remember seeing them and my chiltons doesnt really show how they are held in place, just that they are important. i am going to be replacing my engine in the next few weeks and was wondering if i could just reuse the ones that are in there already. here's something i found online:
Ford Motor Company has developed specific guidelines for installing the oil pan on it's 4.0L engines. On these engines, the transmission bolts to both the engine and oil pan (see diagram). For this reason, before the transmission is
installed, it must be determined what the difference is between the surface of the rear face of the oil pan (at the spacer locations) and the rear face of the engine block.
After installing the oil pan on the engine, position a straight edge on the rear face of the engine block making contact with the transmission mounting machined face on the block. Extend one end over one of the oil pan/transmission bolt mounting pads.
Use a feeler gauge to measure the gap between the mounting pad on the oil pan and the straight edge. Repeat this procedure for the other mounting pad on the oil pan. Select spacers of the required thickness from the chart below.
Install the selected spacers to the mounting pads on the rear of the oil pan before bolting the transmission to the engine.
Failure to install the correct spacer can result in insufficient or excessive clearance between the engine oil pan and transmission. This can lead to oil pan damage and/or oil leakage€
The 4.0L engine is used by Ford Motor Company in Explorer, Ranger and Aerostar applications.
Spacer Selection Chart
Measured Gap Spacer Required Shim Color
mm inch mm inch Code
0.27-0.51 0.011-0.020 0.254 0.010 Yellow
0.52-0.76 0.021-0.029 0.508 0.020 Blue
0.77-1.00 0.030-0.039 0.762 0.030 Pink
