Willy_B
- November 19, 2020
- Eaton, Co
- 2018 Explorer Sport
I just downloaded FORScan yesterday as my F250 is having issues as well, but my current BT module won't connect. So I ordered their ELM or what ever they call it. So I am waiting for that.I agree that 100 down to 75%, overnight, seems excessive however I also wouldn't base any decisions on what's reported by a battery charger without knowing exactly was X% correlates to.
If you have Forscan (and perhaps other tools) you can interrogate to get what the car thinks the charge level is at. Have you tried this?
Again though, this is an indicator only and not absolute. For example, before I most recently replaced my battery, it would commonly show the battery at 20-35% and yet I never had an issue starting the car
I just went out and tried to scan the explorer with my FOXWELL scanner (644Pro). It's a pretty robust scanner as far as hand held scanners are concerned...if you ask me. It doesn't perform miracles by any means, but it reports back very detailed info on the codes.
I have an 08 BMW, 2016 BMW, 2004 F250, and the 2018 Explorer. Up until now, I've never used this scanner on the explorer, but on all other vehicles. Autoscan always finds the vin automatically. I tried to scan the Explorer, and Auto scan failed. Came back with vin FFFFFFFFFFFFFF. Right?!!
I put the vin in manually. It came back as a 2.0L ISUZU.
I went in an even different route, and did an obdII entry. Still wasn't able to scan, but it did recognize it far enough to see it was the right vehicle enough to be able to reset the battery. But that ISUZU thing concerns me.
I tried the engineer menu trick. Pretty cool. Odd thing is that it reporting that my battery is only giving back 12.1V.
I put the multimeter on it battery posts, and it holds a steady 12.98V. Again, brand new battery.
