If all the other windows work chances are you have a bad window motor. You can pull the door panel,and unplug the motor and check for power to the motor with a simple test light.
I had several electrical issues with my 02 xlt. The dome lights would stay on until the battery saver feature turned them off, the driver side puddle light didn't work, the keypad on the door would set off the alarm when I pressed it, the door ajar light would flash and beep at highway speeds, etc.
A lot of electrical issues can be traced back to broken/damaged wire(s) in the boot between the body and the door. I found a broken wire and repaired it and all is back to normal!
