speleopower
- December 26, 2010
- cocoa bch
- 1997 Aerostar
I just changed the rack on my van since a boot ripped and figured it was easier to swap the rack than mess with the boot. I can swap the rack pretty quickly.
But in the rack I got from Autozone the instruction sheet mentions removing the "check valve" from the old rack and putting it in the new rack on the pressure side.
I don't have any memory of swapping the check valve over and I returned the old rack for the core about a week ago. In the mean time my steering is wierd. It seems to have a dead spot. That is I can turn a sharp corner to the left and come back to driving straight but the steering wheel is ****ed about 1/4 turn off. But I can jerk the wheel to the right and continue going straight and now the steering wheel is lined up perfect.
The same happens if I make a turn to the right. Van will drive straight but the steering wheel is about 1/4 off to the right this time. But I can yank the steering wheel to the left and the van will continue to drive straight and the steering wheel is now straight. The alignment is pretty much spot on as verified at a shop with alignment equipment. Power steering was bled etc etc. The only thing I can think of is I didn't swap the check valve.
I went to Autozone and told them what was up and thought maybe the replacement rack was bad. They hooked me up with a new rack. But I don't know if I have the little check valve. Again I have no memory of swapping the check valve and my Dad who helps doesn't have memory of swapping the check valve either.
Does anyone know what the check valve is and what it does? Could a washer with a small diameter hole work the same? I've asked Autozone, Advance and have looked all over the net for a repalcement check valve but have not had luck finding a replacement.
Help!!! Scott
Help!!! Scott
