yes PB400. I had spoken to factory directly before ordering from a dealer, and found out that powder coating, in my case Silver, was an optional extra cost ($20,) Note, there are available in either steel or aluminium (I got aluminium due to weight considerations, and it is pretty tough - check my photo albums)
definitely the 30" light bar will fit. I believe there are identical models, not under the "Rigid" label available on eBay for less than $200. (specs are identical)
I see two options for mounting, either attached to the flat surface of the cross plate, or mounted low, on the brackets (where I mounted my spots)
The Setina, by the way, can be ordered with strobes or without, the strobe controller being built in, making wiring simple.. The no-police option strobes can be amber or white. Basic PB400 (no lights) runs a bit under $300, with strobes about another $200.
I did have my DRL activated. The lower round LED is wired to the DRL bulb wiring directly.
Glad to be of help. Come visit the islands one day.
