itzbinnice
- May 14, 2001
- Long Island, New York
- 95 Xlt Black
On my 95 XLT the radiator was replaced last year at a repair shop. I don't use the vehicle much. I have been noticing when I check the water level in the radiator when it's cold it seems to be low. I also noticed after I top it off, then use the vehicle for awhile, the water level in the overflow tank rises when the vehicle cools down and remains at that higher level.
I just wonder why if the radiator gets low it doesn't draw from the overflow tank.
The vehicle has no water leaks and oil level remains the same and has no water content. The heater works properly and no interior leaks. The water pump was changed several years ago and the vehicle does not overheat and i get good heat in the cabin.. I changed the radiator cap and it made no difference. I just checked it now and had to add a bit shy of a pint of 50\50 mix to top it off.
At first I thought it was a clogged hose from the overflow to the radiator, but that can't be it since the antifreeze is going from the radiator to the overflow tank.
Any suggestions on what can be the cause?
