PUR PONY
- November 30, 2000
- CT
- 96 LTD, 96 XLT, & 98 XLT
i would like to know if I can use a regular threaded bolt to hold the pack together. the factory bold had a round head and non thread shaft till the end where the threads where. I went and torched that off cause I installed a pro-comp add a leaf and then used the bolt that came with it.
No I want to remove the add-a-leaf and i need a bolt to hold the pack together.
should i go to ford and get a factory bolt or can i just use an bolt and grind the head down so its round????
will it be strong enough?
thanks
thanks
