I fixed my 95 Limited rear seat. First you have to remove the 60 side of the seat. There are six bolt holding it down. I used a 3/4 and a 19/32 deep well ssocket plus an extension. This is a little hard to do by yourself. Put the seat on the ground. Stand behind the seat. On the right side you'll see the dual control levers. Turn the seat over so you can get to the levers easily. You'll see a roller wheel with a cable attached. Pull the cable stop out the wheel with a par of needle nosed pliers. The wheel slides off. There are 2 notches on the wheel. You need to make a new notch between the existing notches. Put the wheel back on and re-install the cable stop. Re-install the rear seat. What happens is over time, the cable stretches and won't let the left side of the seat release. If your mechanically inclined, it takes about 45 minutes. Good luck!
