lincolnshibuya
- July 1, 2014
- kc mo
- 2002 mercury mountaineer
the hub can be taken out easily by a hub grappler type setup using an impact or using the brake rotor (smash the upper plate using a sledge hammer - Fordtechmackulo used this technique) to support the knuckle and a 12 ton press. In my case I have a hub grappler, FWD bearing adapters and a craftsman 1/2" portable impact did the job and was able to re-use the hub. It's the outer race that's stuck to the knuckle that's tricky to press out.
