rear window works (some times)? | Ford Explorer Forums - Serious Explorations
pwaltrip
mckinney texas
2005 explorer
I have a 2005 explorer and about a week after all my warranties expired the rear drivers side power window stopped working. A few weeks went by and I noticed that my daughter was rolling it up. It worked for a few months then it went out again? I am hoping that someone else has had this problem and knows how to fix it. Thanks in advance for any help!!!!
This worked on 2 Chevys and a Nissan I did.
I took the switches apart and cleaned the contacts.
I will give that a try tonight, thank you for the tip!
Wires in the door jamb, cut, frayed, or a ground issue with the switch and its wire.
Usually in the bundle of wires between the door and pillar in the rubber boot area.
Common problem someone just posted a fix here.
It could be the power wire from the master switch to the RR switch is partly frayed or now seperated in the driver's door jam conduit, as jrford said. There are also two TSBs on this issue.
TSB 06-21-14 says to tap on the lower area of the interior door trim with a rubber mallet to 'unlock the motor'. Then run it up/down a few times, then install a foam rope into the upper weatherstriping to 'change the rate of glass deceleration'. It would also probably help to clean the leading edge of the glass real well and put some silicone cleaner on the rubber weather seal.
TSB 07-16-14 supersedes 06-21-14 and says to replace the window motor or the whole window regulator if it's damaged. I don't think you can get just the motor for the front windows, so my guess is that Ford got tired of replacing the whole regulator on the sticking rears and made a better motor available as a seperate part. Part number 6L2Z-7823394-AA, Regulator Motor Asy.
Let us know how you make out. My RR is stuck right now, but I don't have kids and rarely use the back seat in mine. So I've been putting it off. I did try rapping on the door panel but that didn't work for me. Good luck.
as soon as my wife gets home with it, i will try that thanks for the detail!
