- July 5, 2003
- Brockton, MA
- '93 XLT 4x4
Hauling my snow blower around in the Explorer's trunk area was a pita. In order to shut the hatch I had to leave the rear glass open and tilt the snow blower back so the handles could stick out. Even with a rubber trunk protector the melting snow still made a mess of the trunk. A receiver hitch basket would allow me to carry it and keep the mess outside.
I picked up the angle brackets at Home Depot (cheaper than Lowes or local steel supply). The steel comes with a protective coating so I used the angle grinder to remove it at all my welding joints. A sander could also have been used, but at a mush slower rate.
Dimensions 30" x 48" x 1 1/5 high. Approx Cost: $86
Note: I had to buy a full 4' x 8' sheet of Expanded metal $51, but only used 10 sq ft for the project.
I picked up the 2" Square tube and expanded metal at Turner Steel. I picked up the angle stock at home depot (Cheaper than Lowes or Turner Steel)
An Angle grinder with cut off wheels quickly cuts all the steel.
To ensure good support for the snow blower I placed the stringers about on-center with it's wheel track width.
Since the stringers were at the same height as the frame I attached Stringer supports (Underside of basket):
Here is the basket frame ready for the expanded metal floor. Notice the left side is open as it is where the ramps attach:
The expanded metal floor has been installed with a tack weld at each contact point (108 in all). This greatly aides to the structural integrity and rigidity of the unit.
Expanded metal Close up:
I made 5' ramps out of 2x8 lumber and some aluminum ramp ends.
Just about all Fab'd up. I just need to drill some holes for tie down hooks. For rust prevention I am going to sandblast it and give it a few coats of Por-15
Notes: The 2" Square tube fits perfectly within the receiver, but I noticed a tiny amount of slop (1/16") at the receiver. This translates into a 1/16" movement on the centerline that grows to about 1" as you reach the extreme left or right sides of the basket. I searched the Webb and found this wobble is completely normal and can be minimized by using various anti-rattle devices.
- $42 Angle stock
- $28 Square tube (2")
- $16 Expanded Metal (3/4 #9)
