Tired Iron
- November 12, 2009
- Black Daimond, WA
- '94 sport
I got the famous "click no start" problem. Tap, tap on the starter, it fires right up, drive it home. This happened a couple times so I got the new starter. Here's my problem- The new starter has a different solenoid wire, it has a ring terminal instead of the old spade terminal. There was a manufacturer not in the box saying "due the numerous no crank symptoms, we have changed the wire to the solenoid to a bolt on instead of the original plug in style." (paraphrase) Does this mean my starter may not be TU, can i just clean the corrosion from the spade terminals, slam it back in and get my $130 back? That's a lot of cheese burgers right there.
It's a new (not reman) starter from BBB Ind. #N3224 Called 'Superior 1'
