Replacing Upper Radiator Hose | Ford Explorer Forums - Serious Explorations
duke16
Raleigh, NC
1997 5.0L AWD XLT
I need to replace my upper radiator hose. Can I just take the old one off and stick the new one on? Or do I need to worry about getting the air out of system?
Easy replacement, but you will need to refill the system afterwards. Fill it, crank the truck and let it run a little, fill it again, run it, fill it again until you cant fill it anymore. Also, when you replace the hose, replace the clamps as well. They can wear out after a while.
Cool, thanks.
when i replaced mine, before we started it, we "squeezed" (like a ketchup bottle) it to get out any air and let the coolant get in there. that made it a little easier. when we started it, we did the same thing, it wont' be that hot at first.
Yep, sometimes called "burping" the system.
