wdl836
- August 26, 2009
- Charleston, SC
- '95 4x4
I've searched the forums and couldn't find a similar issue, so I'm going to start a new thread for this question. If it has been answered before, please accept my apology.
I have a 1995 EX, 4.0, 4x4. The odometer stopped turning in 2005 with 208k. I’ve never had many problems. I had to replace the fuel pump about 6 months ago.
I’m having a problem with re-starting my EX after it has been sitting for between 20 and 35 minutes. The other posts that I’ve found say they have this issue from a cold start or at red lights. It starts perfectly if it’s been sitting for more than one hour. I’ve documented the time frames on my numerous trips to Lowes for work. I have to make each trip short, or deal with the rough idle and stall.
Each time this happens, I turn the ignition; it starts, idles very rough and then stalls. I then turn the ignition to off, remove the key and repeat the process for approximately 3-4 more times. To get the truck moving, I have to put it in neutral, start it, rev the throttle and quickly put it into drive. It will run rough for a few seconds and then run perfectly.
I took it to a friend of mines shop to check the codes and got nothing.
Some similar (cold start or red light) posts have given a few solutions, but I wanted to see if anyone has ever had this exact issue. Their solutions were; fuel filter, IAC valve (clean or replace), fuel pressure regulator, exhaust gas recirculation valve, mass air flow sensor or vacuum hose.
Any ideas where I should start? Thank you in advance for any guidance. We don’t have a lot of money to spend on guess and check repairs.
