dynamite196
- September 22, 2006
- Glastonbury, Connecticut
- 97 Sport
What sort of driving are you doing?
It's your truck so do whatever you think is best for it, but with that sort of driving I would def change it every 3k (not using synthetic). Just out of curiosity how often do you change the tranny fluid?
it is all about preference...
a select few would change transmission fluid at 50 thouand miles
while most would change it yearly or at least every 2 years..
i neva knew it was bright red!!! WOW..
That makes me question your analysis, while the physical make up of the oil may be okay it certainly has lost it's lubricative properties.
The manual recommends 50k for the transmission change interval, talk to any reputable tranny shop and they'll tell you do it every 20-30k and your tranny will last much longer.
Now wait a second, this is a different ball game. Cars (or more so, engines) that are built and designed to run on synthetic only are different engines altogehter.
It's the same like saying a turbo car requires premium gasoline, so your naturally aspired engine would benefit just the same. As we all know, not true at all. Turbocharged engines are designed to run only on premium or better, and it would not surprise me in the least if synthetic-only based engines were built slightly differently as well.
Afterall, these engines ship from the factory with synthetic, yes ? Then tell me why if you buy a brand new car that uses dino oil (a Cobalt, a Fusion, a Focus, whatever), they say do NOT use synthetic oil until minimum 20,000km, otherwise the piston rings will not seat properly because synthetic oil has too many lubricating properties ? If a Corvette engine can run synthetic from the factory, then one can assume that the internals are different and can accomodate running synthetic from day 1.
I'm not debating that synthetic is a bad oil, I've read a book worth of information about the benefits of synthetic oil. Synthetic oil, on paper, is a much better fluid than regular dino oil. However, in practical application, I've personally seen with my own two eyes many engines cave in soon after switching to synthetic.
Again, let me restate, I'm not saying synthetic is a bad oil, I'm saying that in first hand use, I have witnessed bad results numerous times.
Oh, and just an update, 2 weeks since the oil flush on my father-in-law's Dakota, and it's burned about 1.5 liters of the synthetic oil. It's been re-filled to full and we'll see what happens by the weekend.
All I know is, I have yet to see a single instance where an engine with synthetic oil has not failed within 1 year of the dino->synthetic switch.
You're not looking hard enough. I've used synthetic for eons and have never once had a problem, not even close. My current ride ('99 Eddie Bauer) has Amsoil synthetic everywhere possible. So did my previous ride ('00 Sport). Before Amsoil I used Mobil 1. Never an issue. Synthetic is the sh*t. You're getting bad advice. VERY bad advice. You're also giving it too. :thumbdwn:
You must be wearing blinders.
How many of these failures have you witnessed?
you are an island unto yourself because your the only one I've ever heard say anything bad about synthetic oil besides cost. My brother in law has never said anything bad at all about synthetic and he's a senior master technician for Ford dealers so I would imagine he sees quite a few more vehicles and how they're dealing with fluids and whatnot.
