Wrench
- December 30, 2005
- Courtenay, BC
- 99 B4000 4.0L OHV
I see that there are two versions of the VB boost valve - OEM and an increased ratio. When the description for the boost v/v says that it improves line pressure rise, what exactly is happening. Why would you use the increased ratio version?
Also I notice that an o-ring end plug kit is offered for certain VB ports. I was wondering if you put the sealed end plugs in you might be cutting off the flushing effect that minor leakage might create, cause the port to become contaminated prematurely and destroy the bore/spool. When would you use this kit?
