Will the front driveshaft out of a 99 expedition with a 4.6 work? It has a plates at both ends like picture below no yokes
Length is correct. The 97-02 Expedition and 97-03 F150 with the 4.6 use the same front shaft. I believe you will need to remove the flange off the front end and replace it with a 1330 to 1310 companion U joint.
I finally have the rear driveshaft; this is supposed to be out of a 2000 expedition 5.6 4x4.
I picked up the bw 4406 transfer case the other day out of a 2000 F150 4.6 with front driveshaft attached. The front shaft is a toothpick compared to the rear. Hopefully all these parts are right. Now to get the u-joint's and a new trans mount then it is time for the install.
