jkexplorer
- July 16, 2004
- San Francisco, CA
- 2000 XLT
I’ve replaced the front and rear pads on my 2000 Explorer 4x4. The brake pedal seemed somewhat spongy after the pad replacement, and since the brake fluid hasn’t been replaced for awhile I flushed/bled the system using a pressure bleeder (Speedi-bleed). The pedal still felt spongy, so about a week later I repeated the bleeding procedure. I believe there may have been a minor improvement, but the pedal still feels spongier then before I replaced the pads, unless it is my imagination. According to the Haynes Repair Manual, since this is a year 2000 Explorer, there should be no issues with air getting trapped in the master cylinder or the HCU. In any case I believe that I did nothing to introduce air into the system. When I bleed the brakes, there doesn’t appear to be any air coming out of the calipers. Any suggestions on what else I can do to improve on this spongy brake pedal will be appreciated.
