mounty_man
- April 7, 2010
- New Jersey
- 1999 Mercury Mountaineer
Hello all,
I have had my '99 Mountaineer 5.0L V8 AWD for 1.5 years now. Since I bought it, I have replaced: MAFS, A/C Clutch, 2 Front Wheel bearings, Front Pads & Rotors, Intake Manifold Gaskets, Fuel pump, Fuel filter, Idle Air Control, and PCV Valve and have done a rebuild on the front drive shaft CV joint. Things still broken that need attention: the radio and dash lights do not work, the cigarette lighter hole has broken free of its mounts and is rattling inside my dashboard, and the current problem.
(NOTE: This is not a thread to complain about the reliability of this wonderful vehicle but rather a cry for help.)
I was recently on a 400 mile trip from Pittsburgh, PA to my home in New Jersey. On the trip, the cruise control was set and things were going great until I began going up a rather steep hill that required the computer to press the accelerator and down-shift to maintain speed. The problem is that the pedal went down, but the engine was not responding. After the car slowed down (due to the engine not responding), the car came back to life, jolting me back in my seat, and continued as if nothing had happened. I thought that it was weird until it began doing the same thing in every similar situation. When I got closer to town, I slowed down to navigate the windy streets and to my surprise, the pedal was unresponsive at times at slow speeds as well. I got home and parked the car for the night and waited to see if it was acting the same way the next day. I haven't had a problem since then...
...Until tonight. I was almost home from work when I came to a red light. As I slowed to a stop, the car sputtered and stalled but not before the oil pressure gauge quickly jumped from normal to high to low. When the light turned green I desperately tried to get it started again but no luck. I let it rest for a few seconds and tried it again and it started (roughly)! I pulled it over to the side of the road but it sputtered terribly again so I shut it off. I immediately thought that there might be an oil pressure problem because of the erratic needle movement so I checked the oil. The oil was lower than the last time I checked it but not so low as it should cause problems. To be safe, I added some oil that I had in the truck and checked the level again and it was back up to a good level.
I let it cool a bit before starting it again and drove it down the street to the advance auto in hopes that a computer check would show some indication of what was happening. They informed me that the computer check would only show codes that would trip the check engine light on the dash. Their recommendation was to go to a local repair shop. I only live down the block from the advance auto so I was able to get it home in spite of its objections.
Again, the symptoms include sputtering, unresponsive gas pedal, rare stalling, rare oil pressure gauge fluctuation, very rough idle at times.
Leading suspicion: Bad FPR.
If anyone has any ideas, please let me know! This forum has never let me down with any of my other questions, I hope this is not the exception!
Thanks,
Mounty
Thanks,
Mounty
