Now I've successfully managed to drive it for the past 20 minutes or so. It will start and stay running every time now.
The only issue that still exists is it's almost like I have to be very careful not to put too much of a load on the engine at once. (AC on, Lights on, In Gear, etc) During my 20 minute drive just now I was able to accelerate at a pretty normal rate. Actually seemed like I had quite a bit of power now. But during that drive it stalled on me once. I pulled into a gas station and put the truck in reverse where it died pretty much right after switching gears.
I was able to start it back up no problem and drive around some more.
I can also run it with the AC on, but I have to be careful once again not to overload it. (Letting vehicle idle steady before turning on AC)
When the AC is on and I switch to Reverse or Drive the RPMs drop very low and it almost, if not stalls.
My power steering is still choppy. Here's a video of what I mean. -
Power Steering Choppiness (Every time you see the wheel slow down while turning, that's when it gets stiff)
I plan on changing the power steering pump if that is the only thing that could be causing this issue.
What would be causing it to stall intermittently, and under load at different times?
