alchemist
- June 15, 2003
- Baldwin, WI
- 97 XLT 5.0 AWD and 95 XL
Well my starter on my 95X won't disengage.....today it did it once and i turned the key to off (still kept cranking) turned it on/off twice more and it finally cut out (and engine ran). Well it didn't do it for the next three or four start cycles then it did it again.....only this time it stuck on and I couldnt get it to stop.
Well I had no choice but to drive it 1 mile home with it still engaged. Well it finally disengauged after turning the key to park and on a few more times....so I parked it.
Of course the starter is fried (smells electrically burnt). Can my wires be fried as well (or should the fuse/relay stop that).
I'm concerned I'll do it to a new starter as well. My ignition switch will turn without a key if I take it out before it locks (or is that a separate issue).
Any help would be greatly appreciated as to what happened, what to check before I damage anything else.
