- February 8, 1999
- Wayoutin, Aridzona
- '93 XL '20 ST
- Callsign
- AB7FH
How to: 2002 Explorer rear wheel bearing replacement
How I changed my 05's Front Wheel Bearing
How To: 3rd Gen Rear Pinion Seal and Gear Oil Replacement
Fuel Filter Replacement w/pics
How to: Replace Front Blend Door Actuator in 3rd Gen Ex.
PATS key success! Thanks Forscan
How To: Replace Multifunction Switch
How To: Replacing Upper Ball Joints on a 3rd Gen 4x4
Latest PCM Upgrade 1U7A-12A650-GMB for the 2002-2005 4.0L SOHC
Have a 4.6L? Here's a problem I bet you all have...
How to: Replace Sway Bar bushings (frame only)
Keyless entry pad code location
4.0 Harmonic Balancer - know when it's going bad & how to fix
2002-2005 Owners Manual Links
How to: Diagnose and repair Airbag Code 33
How To: Upgrade and Beef-up 5R55W/S Transmissions
Solved - Air conditioning drain problem causing transmission shudder
So my 2003 Explorer XLT AWD 4.0 V6 started developing a weird transmission shifting issue over the summer. When I would sit for a period of time with the air-conditioning on (such as in a drive-thru), as soon as I would pull away, the Explorer would shift funny. What I mean is it might slip...
www.explorerforum.com
