- November 11, 2005
- Brooklyn, NY
- 88 89 93 95 96 Aerostars
Check the PCM ground wire connector for corrosion.
You said that the PCM circuit had excessive resistance, so a different valve body won't help if that is the issue. Back tracking to a previous post, you said that the internal wiring harness in the transmission was good but the wiring from the PCM connector to the transmission had excessive resistance on a few wires (around 75 Ohms). I assume that you checked each wire from the PCM connector to the main bulkhead connector on the transmission (or at the solenoids inside the transmission).
I saw a recent post about somebody which had a no drive or reverse situation, and wanted to rule out the possibility of an electrical issue. He unplugged the main bulkhead connector, and the transmission had drive & reverse gears. He lost these gears when he plugged the connector back in. Try this then get back to me.
I thought that I saw it posted in another thread. Looking back at post number 26 in this thread I saw that you posted it.
A transmission shop has a special scanner (or should have) to simulate driving conditions while the vehicle is not in motion. It will cycle the shift solenoids, vary the EPC pressure, and vary the TCC apply rate.
You could send the valve body out to be tested by Central Valve Bodies to rule that out.
This is where that scanner would come in handy. It will automatically simulate these tests.
Check WWW.ATRA.Com for a local shop. Maybe they have one close by.
The PCM receives a signal from the VSS when it's in motion. The transmission also has internal speed sensors on certain models. These sensors tell the PCM when to shift to another gear ratio. A scanner will simulate the vehicle in motion even though it's not moving.
