I have just reread the post and nowhere unless i missed it have you ever taken a pressure reading. By unplugging the trans connector you are setting high line presure by taking the EPC out of the control of the computer. So yes you probably will see some difference in the way the transmission acts. As it is overcoming a low pressure problem. I think you may be chasing the wrong culprit. good luck and let us know what you find
you are correct sir! I have not done a pressure test, I don't have a gauge, there is two feet of snow on the ground, and my explorer is dead from my stupidity. is it a special gauge? I have an old fuel pressure and vacuum gauge for cars pre fuel pump, I think it only goes up to like 50 psi. it has just a vacuum hose though. what kind of "end" does a trans gauge have? how much are they? can I get one at Advance auto?
Let me ask this again. with the car running, and in park or any other gear, all four shift solenoids have 12v to them. does that mean they are on? is this normal?
because in park only SS1 should be applied.
in Reverse only SS1 should be applied with the O/D button pushed, and SS4 would also be applied if O/D on.
The TCC has 12v going to it all the time.
The EPC has 10.6v going to it all the time.
no change when you shift through the gears.
how do you electrically test the DTRS?
thanks again for all the help guys. i am going to take it all off again this evening, and check the Solenoid bracket again. then pull it down check everything else again. i am also going to adjust the od and intermediate bands. i'll be sure and update.
