Coming out of my sub-woofer Amp (From an Explorer LTD) there is a thick red and a thick yellow wire, anyone know where they are to go? +? -?
Thanks....
yea i would recommend doing that as well.. everything for a system is my explorer is all custom..i ran new wiring for my doors to an amp for that crystal clear mids, highs that i crave .. now the problem im facing is where the hell im going to put a power cap when i drop some new 12's in my truck
Are those the only wires coming out from the amp? Should be a bunch.... If you already have the speaker wires sorted and the ground wire figured out, both should be power of some sort, one turn on, the other power.
If I remember corectly those wires are for power to the amp. The plug on the other side of the amp is for the remote turn on and signal feed coming from the main amp.
