LTCPipkin
- April 8, 2010
- Netcong, NJ
- 2005 XLT, 1993 Limited
Picked up a thermostat for my 2005 4 liter non-flex a couple weeks ago at Advance Auto...had to replace the thermostat lower housing and associated gaskets, decided might as well replace the thermostat while in there.
When I went to drop the new thermostat into its location, I discovered that it was much smaller (including diameter) than the thermostat I was removing. I checked out the box and noticed it was a 195 degree thermostat. I drove on over to my local Advance Auto to get the right thermostat (with old one in hand) and discovered that the OEM choice on his comuter for my motor/year showed the smaller part number at 195 degrees. He scrolled down on his computer and found one that showed as "optional" for my motor and collected it from the shelf. It was indeed the correct size and looked exactly like the old one...with one exception. This correct size one was rated at 180 degrees. My old one didn't have any ratings, so I assumed it was correct and installed it.
My question is...why was the smaller one that his computer suggested was correct rated at 195 degrees and this "optional" one rated at 180 degrees?
I know I installed the proper "size" thermostat...but did I install the proper "temperature" thermostat?
Thanks,
Michael
Thanks,
Michael
