You will need much more than just the puller. For starters, you need the installer as well, and that one is actually more critical. You will need the proper thin wrenches to remove the fan, a serpentine belt removal tool, most likely an impact wrench, a torque wrench, a tool to hold the pulley in place when you are re-torquing the center bolt, and so on. The workshop manual is great, but it's intended for professional mechanics. It often calls for some Ford-specific tools that you probably won't have, and more importantly, does not tell the whole story, with all the little gotchas along the way. Search and carefully read the posts on the subject, before even thinking of starting this task.
Most common tools can be rented for free from auto parts stores, like Autozone. They will charge you for the full cost of the tool, which will be refunded when you return it within their time frame (a couple days, usually). Sadly, many of their tools are sub-standard. Even those of decent quality will be generic and may not fit your vehicle very well. If you have a mechanic friend, try to enlist him (and his tools) to help. If you have a couple hundred $$$ to spend, buy a decent puller/installer kit, a good 1/2" torque wrench, the fan removal tools, and a good serpentine belt tool. You will use those more than once. If you find my two-year old post for this job, I listed some tools by part number and vendor. If not, Amazon is your friend... . I am assuming that you have a compressor and an impact wrench. If not, buy those. You will wonder how you ever managed without them.
And by the way, even though it's a common problem for this engine, you don't want to tackle it unless you are certain of the diagnosis. With all due respect to Midas, I would advise you to rent a radiator pressure tester and confirm that the leak is indeed from the timing cover gasket.
Thank You lilredex97 and 1998 Exp, your replies help a lot, sorry for not putting more info on my post but my engine is a V8 5.0L and it has 155000 miles on it. I have a complete teardown repair manual for my mountaineer which has helped out a lot already but where can i get a pulley puller for my crankshaft pulley?
