Toggle switch mounting idea | Ford Explorer Forums - Serious Explorations
Hayden, ID
98' Base
Hello this is how I mounted my toggle switch in my 98 x. it's kinda hidden but still easily accessible
This is what my center console looks like
Pop the cup holders off pull at the part closest to the dash
Drill a hole in the center or where ever you want and mount it in there
Run the wires through the hole that's already there unbolting the bolts pictured will make this easier
I ran the wires under my seat and under the trim then through the fire wall you could probably run the wire under the carpet. keep in mind i have manual seats
This is what mine looks like and i still have room to mount more
Hope this will give you some ideas
Where's the pics?
Click on the <Insert Image Button>
in the toolbar at the top of your message reply window or become an Elite Explorer and you can upload directly from your pc instead of an image hosting site.
When you go to the links you posted just copy the "IMG Code" directly into your post. Do this for each picture and you will be able to see them without going to the link.
They were there, but that was 2-1/2 years ago, page probably went dormant.
