zeka
- July 4, 2002
- Newton, NJ
- 1992 Explorer XLT 4-Door
...So I decided to give my x some tender loving care -- dealer cared for it prior to now; I have taken wrench in hand and am enjoying it.
1992 4 door 4.0L Manual 169,000 miles.
I decided to change all of the oils. When changing the tranny oil I did a boo boo; I drained it and filled it with hypiod gear oil -- because I had it. I think it was 90 wt. Well to my amazement the manual calls for dextron III ATF -- oooops! I ran it that way for about a week, but only on short trips, 20 minutes tops.
Prior to making the oil change, I was having some trouble shifting into first from a stop. The shifter was just hard to put into first -- unless I first did a little line up by first going into second (didn't actually have to go all the way into second, just had to move the stick a little in that direction) once I did this the shifter would go into first easily -- I have experienced this in many of my cars, the older volkswagen beetles behaved this way. I would also get some slight grinding if I didn't first nurse it into 1st via 2nd.
So once I made the oil change to gear oil then getting into 1st was about as hard but with less grinding, and the shifting seemed to work more smoothly.
Well I didn't want to go against what was recommended so I drained and refilled twice. The first time was intended to flush out the gear oil. I used Dextron III ATF and ran with that for a couple of days. The Dextron III ATF mixed with the residual gear oil seemed to work really well regarding shifting. I then drained and filled with amsoil synthetic universal ATF. Now the tranny does not seem to shift as well. It will grind in first if I don't do the 2nd gear line-up procedure from a dead stop -- not a problem if you are rolling though.
I am wondering if it would improve the shifting if I added a pint or two of amsoil gear oil.
Is it a bad idea to mix the ATF and the gear oil?
I have zero experience with ATF since all of my cars were manuals and all of them used hypoid gear oil.
