Isotrip®
- December 5, 2001
- Michigan
- '92 Sport
Well my 5 Spd. tranny went out on my '92 X and I got a replacement from a used parts place (read: Auto Salvage) the replacement came out of a '91 Navajo. Anyways.. I got it home and I went to check the fluid level and it smells like there is Gear Lube in it instead of ATF. Now I was under the impression that ATF is required for all OD trannys and if you put Gear Lube in them than they become almost impossible to shift when they are cold. Can anyone here confirm whether I use ATF? TIA!
