Justinwht
- August 12, 2014
- Location
- Rosston and Fort Worth, TX
- Rosston, Texas
- '96 XLT, '96 XLT, '00 XLS
Does the front axle gear need friction modifier as the real axle does?
Quoting from the owner's manual (tips hat to www.JustGiveMeTheDamnManual.com), it has two footnotes.
Transmission fluid -
Motorcraft MERCON ATF - 5-speed manual (Yes I know to use Mercon and *not* Mercon V)
Transfer case -
Motorcraft MERCON ATF - 4WD
Front axle lubricant -
Motorcraft SAE, 80W-90 Premium Rear Axle Lubricant
Rear axle lubricant -
Motorcraft SAE, 80W-90 Premium Rear Axle Lubricant (Refer to - Footnote 6)
Motorcraft SAE, 75W-140 High Performance Synthetic Rear Axle Lubricant (Refer to - Footnote 7)
Footnote 6 - Vehicles equipped with 4.0L OHV V6 and4.0L SOHC V6 engines may be equipped with a conventional rear axle. Refer to your scheduled maintenance guide for axle fluid change intervals.
Footnote 7 - Vehicles equipped with 4.0L OHV V6 and4.0L SOHC V6 engines and 3.73:1 or 4.10:1 rear axle ratios or with a 5.0L V8 engine require synthetic rear axle lubricant. Rear axles containing synthetic lubricant are lubricated for life. These lubricants are not to be checked or changed unless a leak is suspected or service is required. The axle lubricant should be changed any time the axle has been submerged in water.
Add 118 ml (4 oz.) of Additive Friction Modifier C8AZ-19B546-A or equivalent meeting Ford specification EST-M2C118–A for complete refill of Traction-Lok axles.
I was thinking of using Royal Purple for rear differential. What should I use for front end? Does it need a friction additive?
Transfer case -
