tigger432
- January 31, 2014
- central new jersey
- 2001 sport trac
*hi all, i have a 2002 mercury mountaineer AWD 4x4 automatic...here is the problem-i got this truck super cheap. the front differential bushings were completely shot with the center one completely gone. i did drive it to see what the problem was before i bought it,the person selling thought the trans was making the loud banging noise. anyway-i had to swap the entire front diff as the center bushing bore was destroyed. now the new diff is in and the truck will barely move/ i cannot push it in neutral. the tires chirp going around corners. i cannot turn the front driveshaft with it in neutral. i took out the front driveshaft. it's good. now the truck moves as freely as it did before...now-is the transfer case to blame for the front diff problem? seems the old one has no resistance when i turn the yoke...i suspect the vc locked up and ruined the front diff to the point it no longer grabbed...does this seem like a correct thought or is there something i'm missing?? the new and old diffs are both 3:55
