Transmission problem. | Ford Explorer Forums - Serious Explorations
T
tusrfer
have a 1994 v6 4x4 automatic...it's been getting longer and longer to engage when I go from Park to Drive, it goes into reverse right away but going into drive is starting to take forever. Good clean fluid and filter.
any ideas? tim
Welcome to this forum! I've moved your thread into the transmission section. How many miles does it have? Did you ever rebuild the valve body? Did you check the pressure with a 0-300 PSI test gauge in all of the gear ranges?
