Transmission Swap -- Which Models? | Ford Explorer Forums - Serious Explorations
Johnny Glenn
Charleston, SC
02-04 Explorers
Thanks -- some of the info was covered up by an advertisement but I didn't see any inter-change info? Will 01-05 models interchange as so many ebay listing suggest?
The 2001 has a 5R55E which is not swappable with the 5R55W unless you do modifications. I don't think that you would want to put this in anyway since it's a lower model. The later models have the 5R55S which is a closer match, but will still need modifications to be compatible. Look for a 2002-2003 5R55W.
Thanks -- I thought those listing were incorrect. Are the modifications you mentioned complex?...or just not worth the time to chance it? Thanks again.
