cherrybomb
- April 1, 2005
- Southern California
- '99 EB 5.0L (R.I.P)
I finished installing the Trick Flow Differential Cover on my X. Also went with 75-140 Mobile 1 gear oil.
I only have one problem. The bolts which are supposed to go into the diff, and support the bearing caps appear to be too short! The instructions tell me to tighten them down to 10 ft/lbs of torque, then put the jam nuts on them. But there aren't any threads exposed to put the jam nuts on.
I put them in, and tightened them to 10 ft/lbs and left them there. There have been no leaks, and they don't appear to have backed out after some while now. Just not sure if I should be worried about this, and/or if Trick Flow makes longer ones?
too_short by qwikrex, on Flickr
