- June 17, 2004
- Knoxville, TN
- 98 Limited AWD 302
Welcome Lars, is there any chance that you can find out if the front cam chain tensioner was done, and when? That front tensioner is near to an oil gallery port which needs a check valve. Most work including that tensioner includes adding the check valve.
You should hope that for some reason the check valve isn't yet installed, because that is part of the easiest work to do. You can remove the upper intake to get to those, and do that job in a couple of hours. The first TSB had a kit part number for it which includes the parts to do that check valve and tensioner, about $45.
Just like Ford did back during the recall period, you do that first and hope that the more internal parts are okay. Try to find out from the seller, otherwise you are ending up doing that TSB kit to hope that it hadn't been done, etc. Good luck,
