loadie
- March 18, 2007
- Ontario, near the boarder
- 97 XL
Holy crap, it's no fun at all!!!! Especially when you are missing the socket part of the tool. I had to use a 3/8 ratchet and socket, but it worked. No way of telling the torque I put on her, but she's tight for now. I'll get the socket and then re tighten the cam bolt.
I found the problem. Te right cam was 180 deg out. How do I know this, cause it finally sunk in when I had the right valve cover off and looked at the end of the cam. The cam slot was lower on the top when it should have been on the bottom, below the center line f the cam as the instructions say. I guess I didn't know what the hell they meant. I do now!!!!
Now I have her all quiet with the chains, but she is backfiring a bit and and idiling rough. I think it as to do with the new plus and wires. The wires were crap, so I'll take it to the shop and have them swap them out for better ones, also put different plus in as well. I couldn't get to cylinder 3 right side back cylinder. I have no way of getting in there to change the plus. I'll let the shop handle that one. Might also have a vacuum leak. But not sure, it's dark out now and can't tell.
Thanks for all the help guys! I won this one, I hope, well see in a few days or so!!!!!
Dan
Dan
