Explorer23
- December 25, 2010
- Columbus, Ohio
- 92 Explorer
Finally with some clear days I was able to finish replacing body mounts. I used this write up http://www.explorerforum.com/forums/showthread.php?t=122116 and it helped a lot however I put my own spin on it since NONE of the original hardware was reusable. Since I didnt reuse factory hardware or do the 3/4" bodylift I bought the bolts listed in the above how to when I shouldve bought them all about a 1/2" shorter.
I had never messed with body mounts so I had no idea how important the metal spacers and washers etc. were. The spacers fit through the rubber mounts to give rigidity and allow proper torque specs. I was going to simply run a bolt through the poly mounts with a "Dock Washer" on top and a fender washer on bottom. However, on some of the hollow mounts that needed to have something inside (from the factory that on mine rotted away) I wasnt comfortable running them without some sort of rigid spacer to keep them from crushing too far.
I bought some 1" O.D. 1/2" bolt hole by 3" long chrome spacers from boltdepot.com. I cut them to the proper lenghts for each mount. If you cut them too long then the bolt will not torque down far enough. On this build that could be disasterous because airtime is a strong possiblity. On the more "solid" mounts I cut the spacers AT LEAST a 1/16" short and on the hollow ones I cut them about an 1/8" short.
The "above frame" mounts I ran in all the normal configurations however the "below frame" mounts I flipped on about half of the mounts. This was because they're hollow and required some sort of hardware that had long rusted away. The rear mount and the ones that are under the front seats were the only ones that I did not flip the lower mounts.
This was the order that I put everything together for the rear and under seat mounts. I ended up adding a fender washer between the mount and the lowest washer.
I ran the same order for the other mounts except the flipped lower mounts just got MUCH shorter bolts. A thick fender washer fit perfectly inside the groove.
the spacer still needed trimmed but after that it just needed a fender washer, a normal washer and nut.
