rjc
- February 10, 2002
- CA
- 1993 XLT
OK, I'll start
This is what I had to do to get my 92K used explorer in good driving condition.
Radiator
Tensioner
Drivebelt (I was there)
Thermostat (It was cheap and I was there)
Upper and Lower radiator hose and heater hoses
(can't figure out where the hell the valve is but it made changing easyer)
Tires
Radius Arm Bushings + Alignment
Front Wheel Bearings and Rotors and pads front and rear (now it breaks smooth with no wobble or pull and in a straight line).
Transmission flush and filter change.
New Plug Wires and spark plugs (bosch).
New Air filter
I'm now tracking down a rough but intermittent idle problem when warm and have cleaned the Mass Air Flow sensor with break cleaner and let dry.
I will be checking the Air Bypass Valve (IAC) and want to ask you guys now what? I know the engine could run a bit smoother than it is right now. My milage isn't too bad but it's not great. About 18-19 highway and about 13-15 town driving with 235-75-15 Land Terrain (Goodrich) tires. Oh yeh, 2wd not 4. What else should I change/check/clean? EGR? PCV valve? O2 sensor? Thanks for the advice, this site is great! rc
Radiator
Tensioner
Tires
New Air filter
