anomatrix
- April 19, 2018
- 2018 Explorer Platinum
Hey all please help!
I've got a new 2018 Ford Explorer Platinum with the OEM 20" Bright painted wheels, and I'm starting to look into winter wheels and tires. I've Googled all over but not finding much luck with these 2 issues:
The TPMS. Are these the same as previous years? What frequency range? Rock Auto has 3 different partslisted - F2GT1A180AB, F2GZ1A189A which are 315MHz, and another set that are 433MHz. Can anyone shed some light on which work? And if you buy a set online, do you need a special tool to relearn the system?
Also, the brakes. What is the minimum radius that will clear? 17" apparently won't as I purchased a local used set of 17" steelies that will not fit.
TIA
TIA
