heavy_dman
- November 16, 2011
- North Carolina
- 1994 Ford Explorer
Okay, for some reason my wifes 94 explorer dies after getting warm, I get no power to the fuel pump, the relay and the 20amp fuse under the hood are all good, just put in new inertia switch from ford, and am about to go crazy. Now the really crazy part is, if you let it sit for a few hours and cool off, you then can hear the pump again, and it'll crank up and run fine until it reaches running temp,(around 190) then as soon as you stop the car it'll sputter out again, and the fuel pump won't come on, until it cools back down. Has me stumped. Any suggestions.
Additional Info:
Fuel pump and wiring harness are 6 months old
new FORD Relay
new MAF
New Inertia switch
Also, when I replaced the Inertia switch, the wire leads on the old one were a little burnt, but the harness looked good, replaced it anyway though.
Additional Info:
new FORD Relay
new MAF
New Inertia switch
