2000co
- April 7, 2007
- Englewood, co
- '05 Mountaineer V6 AWD
What transfer case fluid you recommend? The delaer told me they no longer sells Mercon and to use Mercon LV.
I read that you can use the Valvoline multi-vehicle transfer case fluid or mobil1 ATF. Will either work and be a better option than Mercon LV?
I just want to make sure I buy the correct fluid. Thanks
