- December 28, 2010
- Russell, Ontario (Ottawa area)
- 2023 Aviator Reserve 201A
- Callsign
- VE3
Going through the firewall in this gen Explorer is quite a challenge as many have found out. Also, there are two fuse panels. One in the cabin and one under the hood.I would highly recommend going through the firewall with the proper grommet or through an existing one and connect to the power source next to the fuse panel if there is one on that model. No question about the current available and you will not have any issues when transmitting due to low voltage possibilities. You should be able to find a good ground or make one close by the same area. I was a Motorola trained technician for 40 yrs. I like to avoid issues if possible. Will it work as you want, probably, would I do it? No.
